Pump won’t stop running
MikeRome
I have a barefoot b7 spa model number 95039. With a balboa control panel and vs circuit board. The tub used to shut off in between cycles now it just runs constantly on the low mode. The heater light isn’t on, I have it set to SL and F2. I lowered Temp to like 95 I checked the temp on the board(102) compared to the actual water temp (101) so it was reading correctly. The pump has gotten louder so I believe the bearing are on there way out. I hosed the filter out to make sure there wasn’t any restriction there all jets are open. Outside temp is around 70-80s here. There’s always a cover on it. Any ideas or things to try?
It actually started working again today after I flipped the breaker back on. I’ve been shutting power of to it then turning it on for a few times a day then one day it began working again. When I turned the jets on high they would work. I’m pretty my pump is on its way out there this last year it’s gotten  little louder
