Johnnotrog Posted May 10, 2021 Report Share Posted May 10, 2021 In need of help! I Have a Hotsprings Vangard 2010, but the top control panel has become very "glitchy" (Only works correctly when the spa is warmed up, and until then screen and buttons don't work, I suspect dry joints.., but not brave enough to tackle it it in case I make it worse!.) I would consider a replacement it but cant find any?? I am in the UK and have been advised I need to replace the main board together with the control panel!!! Ouch!! Anyone had the same? is there a fix / replacement I would value any assistance Quote Link to comment Share on other sites More sharing options...
castletonia Posted May 10, 2021 Report Share Posted May 10, 2021 That control panel is obsolete so unless you can find a used one you will have to replace the IQ2020 control box too. Quote Link to comment Share on other sites More sharing options...
Johnnotrog Posted May 10, 2021 Author Report Share Posted May 10, 2021 Many thanks castletonia, If I cant find a replacement, do you know what complete control system I would need... sorry I am on a steep learning curve with this one. Many thanks John Quote Link to comment Share on other sites More sharing options...
