HELP! Removal of screwless access panel
Karl N
Hi,
Please can anyone help me? I have a home spa and need to get access to the pump. There are no screws holding the panels in place around the spa and I have been told the panels slide and lock into place.
I can't seem to work it out how to remove the panel and don't want to damage the panel by forcing it.
Does anyone know how to do this?
Thank you in advance.
On mine the screws that hold on the wider panels are beneath the 3 thin vertical rails on each side.  However, on mine you can see the screw heads (with caps) on those rails. You might try sliding those rails up or down, or maybe they are flexible enough to (gently) pry off to reveal the main panel screws.
-Rob
