samwise801 Posted February 19, 2021 Report Share Posted February 19, 2021 Greetings everyone! I have a 2007 Hot Spot Mallorca (bought it used, obvi) and generally it works well. Everything pumps strong and save for just a little bit of air leakage in one of the jets, it seems to function as it should. Except, every few days I come out to it and find the Entire Spa Inoperative error (four dashes) on the display. I can't pinpoint what triggers this, as it seems to happen somewhat regularly and doesn't seem to correlate with new or old water, fresh or not-so-fresh filters, etc. The strange thing is, I can always, always resolve it with two power cycles. The first time I power cycle the error will always come back after about 20 seconds or so, no matter what I do (leave the tub alone, turn on one pump, turn on both pumps, wait 2 seconds before turning the breaker back on, wait 60 seconds before turning the breaker back on, etc). But then if I power cycle the tub a second time she always stays on and works as-intended with no further errors. Anyone have any ideas as to what this might be? The manual says the heater high limit thermostat is the most likely culprit, so I replaced that with a new, genuine part. That hasn't seemed to make any difference in the frequency or other behavior of the error. The tub didn't do this when I first got it but picked up the habit last fall. So I suppose it might be correlated with cooler outdoor weather, as I only got the tub last April. (I also tend to keep the tub set a couple of degrees warmer in the cooler months, so there might be a correlation with that too.) So, anyone have any thoughts? What might be the cause here? Anything I'm concerned about / can do anything about? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted February 19, 2021 Report Share Posted February 19, 2021 Try removing the filters. If it stops, get new filters. If not, post a pic of your equipment area and circuit board. Quote Link to comment Share on other sites More sharing options...
