Pumps on or off when adding chemicals?
rmcderm313
3 hours ago, rmcderm313 said:
I have a 2.5HP circulation pump that runs 24/7.
What kind of spa has a 2.5hp 24/7 circulation pump? Based on national average electrical rates that pump will cost you almost $200 per month all by itself.
There is no conflict, you run jets when adding chems. Nobody with any knowledge or sense would say otherwise. Add them into the tub, not into the skimmer, filter well, etc...
  • Thanks 1
Whoops.  No kind of spa has a 2.5HP circ pump.  Total brain fart.  It's 1/15 HP.  My other 5 pumps are 2.5HP. Sorry about that.
So with that clarified, does the rest of your answer still stand?  With all my pumps running there is a ton of agitation.  Should they all be on?
How long should I keep them running after addition. I do leave the cover open for 15-20 minutes.
Finally, what about the blower?
Thanks!
