ThermoSpa Control - How to remove?
rmcderm313
Hi All,
One of the buttons on this topside control (for a wave-lounge) has stopped responding. How do you remove this?  I can't see any screws or other fasteners from underneath.  Is it just sealed on with an adhesive sealant?  Do I pry it off? Use heat?  I don't want to break anything if there is a trick.
Also, once I get it off are there any serviceable components that I might be able to fix, or is this a replacement job?
Thanks,
Rob
Thanks for the reply.  Will the replacement normally come with an adhesive foam gasket to reinstall? If not, what is the recommended adhesive to secure these components?  I've always struggled a bit with when to use which level of adhesive vs. just a sealant.
-Rob
