Rolfy Posted August 7, 2020 Report Posted August 7, 2020 hi all, has anyone had this problem ? When I take out the jet nozzle air is leaking out of the hole at the bottom. This is causing the liner to deflate. Even when the jet nozzle is in place, bubbles of air are still leaking out ? Quote
Dan Bemowski Posted September 22, 2020 Report Posted September 22, 2020 On 8/7/2020 at 8:16 AM, Rolfy said: hi all, has anyone had this problem ? When I take out the jet nozzle air is leaking out of the hole at the bottom. This is causing the liner to deflate. Even when the jet nozzle is in place, bubbles of air are still leaking out ? Sounds like you have a small puncture. If you can't see exactly where it is you may need to drain the tub to just below that point and inspect it. If you can find it, I would use a small piece of Flex Tape to cover it. Quote
Rolfy Posted September 22, 2020 Author Report Posted September 22, 2020 Hi Dan thanks for your reply. I have just drained the hot tub down and the inner liner was full of water ? The only way I could drain the water out was through the air inlet valve. This makes me think there is a leak on the internal hydro system ? Quote
Bruce1967 Posted March 7, 2021 Report Posted March 7, 2021 Hi did you get this sorted? I have exactly the same problem. Quote
Rolfy Posted March 8, 2021 Author Report Posted March 8, 2021 Hi Bruce no I didn't. I managed to drain out all of the water and pump it back up again, but it went down. I took all the hydro jets out and noticed some of the o-rings have split. That was my next job to replace them. That's where I left it for the winter ? Quote
Bruce1967 Posted March 8, 2021 Report Posted March 8, 2021 Hi Rolfy, I removed All of the jets and went to the bother of sourcing Viton O-rings. I fitted the o- rings and reinstalled the jets.😞 leak is still there, the air is coming out of a small hole in the air jet receiver so to speak, which I thought would have been isolated after fitting the new orings. If you place your finger over the hole the air chases round to the next assy and hisses out. I’ve emailed bestway and hoping to hear back, I’ll keep you posted. Quote
Rolfy Posted March 9, 2021 Author Report Posted March 9, 2021 Thanks for your reply. Please let me know how you get on. Quote
Rolfy Posted March 30, 2021 Author Report Posted March 30, 2021 Hi Bruce did you get anywhere ? Quote
Dutch Rog Posted April 11, 2021 Report Posted April 11, 2021 Hi have same problem any news on how to fix Quote
Rolfy Posted April 11, 2021 Author Report Posted April 11, 2021 Hi Dutch yes I have fixed it. I found one of the connecting pipes had split. The only way is to find which corner has failed ? That's the hard part. I then replaced the pipe with a hose pipe the same size. See photo's Quote
Dutch Rog Posted April 12, 2021 Report Posted April 12, 2021 Thanks Rolfy I will try that and let you know how I get on Quote
Rolfy Posted April 12, 2021 Author Report Posted April 12, 2021 Hi Dutch before you make a split in the side of your hottub, I am still having trouble making the hottub get to full pressure. So hopefully you can repair it successfully? Quote
Donald Leitch Posted May 26, 2021 Report Posted May 26, 2021 Hi, I have the same issue with my Maldives, did you find the air leak/broken pipe at the jet that was leaking or was it elsewhere? Quote
Rolfy Posted May 27, 2021 Author Report Posted May 27, 2021 Hi Donald if you blow up the hottub without the water you can hear which corner it is coming from. I have had two corners leak. But I still can't seal the hottub to keep the pressure in ? Good luck Quote
Donald Leitch Posted May 27, 2021 Report Posted May 27, 2021 Thanks for the reply, I will give that a go and let you know how I get on. Are you still having leaks from where you cut the liner or from the internal piping? Quote
Rolfy Posted May 27, 2021 Author Report Posted May 27, 2021 Yes where I cut the liner. I am now trying inflatable canoe patches ? Quote
Donald Leitch Posted May 27, 2021 Report Posted May 27, 2021 That's worth a try indeed. Will give this a go when I'm off shift and let you know what I tried patching with. Quote
Donald Leitch Posted June 28, 2021 Report Posted June 28, 2021 On 5/27/2021 at 10:09 AM, Rolfy said: Yes where I cut the liner. I am now trying inflatable canoe patches ? I cut open the liner and found the burst pipe just like you said, after a fair amount of cursive language I managed to sort that issue, then on to the cut in the liner, I tried various patches and glue to no avail, I then had a brain wave to stitch the liner together with fishing line then patch over the top, the stitching worked well but the patches still couldn't cope with the air pressure, next idea (and running out of them)along with the stitching I put a layer of everbuild fix all over the stitching, let it set and pressured it up and had two tiny holes so I put another thick layer of fix all over the top and let it set, hey presto it's holding tight. Hopefully permanent Quote
Rolfy Posted June 28, 2021 Author Report Posted June 28, 2021 Hi Donald that's brilliant news. I am still on the patch and glue stage. Which particular ever fix did you use, as there is quite a few ? Cheers martin 👍 Quote
Donald Leitch Posted June 28, 2021 Report Posted June 28, 2021 51 minutes ago, Rolfy said: Hi Donald that's brilliant news. I am still on the patch and glue stage. Which particular ever fix did you use, as there is quite a few ? Cheers martin 👍 Sorry it's soudal fix all ( I'm renovating an old house and have various types of sealers and glue) It doesn't look great but grey was the only colour I had at the time. As you'd expect it's very sticky but if you get wonder wipes and wet your finger with them you can spread it a bit like putty. It's very important to stitch it first Quote
Rolfy Posted June 28, 2021 Author Report Posted June 28, 2021 Yes we did stitch it but not with fishing line. Thanks Quote
Donald Leitch Posted June 28, 2021 Report Posted June 28, 2021 5 minutes ago, Rolfy said: Yes we did stitch it but not with fishing line. Thanks No problem, good luck sorting it 👍 Quote
Vicky kilshaw Posted March 18, 2022 Report Posted March 18, 2022 On 6/28/2021 at 2:47 PM, Donald Leitch said: Sorry it's soudal fix all ( I'm renovating an old house and have various types of sealers and glue) It doesn't look great but grey was the only colour I had at the time. As you'd expect it's very sticky but if you get wonder wipes and wet your finger with them you can spread it a bit like putty. It's very important to stitch it first On 6/28/2021 at 2:47 PM, Donald Leitch said: Sorry it's soudal fix all ( I'm renovating an old house and have various types of sealers and glue) It doesn't look great but grey was the only colour I had at the time. As you'd expect it's very sticky but if you get wonder wipes and wet your finger with them you can spread it a bit like putty. It's very important to stitch it first Hi I am just wondering if this lasted, and could u still use hydrojets ? I have same problem and same hottub thanks Quote
Vicky kilshaw Posted March 18, 2022 Report Posted March 18, 2022 Hi I am just wondering did this last ? And do the hydrojets work after this ? I have same tub and problem thanks Quote
TJAG-GB Posted March 20, 2024 Report Posted March 20, 2024 Had the same issue and thought I’d post pics in case anyone else was encountering it. There’s no stitching this one back together! We got about six months of use out of our Bestway Saluspa HydroJet Pro hot tub (it was nice while it lasted). Used it Oct - Mar and packed it away for the summer. Pulled it out to use it this spring and it won’t hold air. Found no external air leaks. I discovered air coming out of one of the jets and the jet vent on the side of the tub. I opened it up to find brittle degraded vent hoses that had broken off. All the jet vent hoses were brittle and just snapped off. This caused the air to leak out the jet and the jet vent. It’s essentially like surgical tubing, which doesn’t appear to stand up to the use case. IMG_5661.mov Quote
