Deann Posted May 7, 2020 Report Share Posted May 7, 2020 I just changed my sand, however, the valve won't go back on. Any ideas what I can try? The pipe appears flush and centered?? Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 7, 2020 Report Share Posted May 7, 2020 Appearances can be deceiving. If it were flush and centered the valve would go on. I know of no way to move it once it is full of sand. If you try to force it you could break your laterals. You are going to have to remove the sand and try again. New filters come with a plastic or cardboard doohickey (technical term) that keeps it straight and prevents sand from entering the standpipe. I do not know what it is called and have never seen one sold separately. You might contact the filter manufacturer and ask. Wish I had better news. Good luck on your next attempt. Quote Link to comment Share on other sites More sharing options...
