Watters Posted May 4, 2020 Report Share Posted May 4, 2020 Auto fill system for in ground pool is not working. How does this system work and is it a DIY fix? Thanks. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 5, 2020 Report Share Posted May 5, 2020 Depends on the system. Can you post a pic? Quote Link to comment Share on other sites More sharing options...
Watters Posted May 5, 2020 Author Report Share Posted May 5, 2020 Here are photos of pool system. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 5, 2020 Report Share Posted May 5, 2020 That is just a float valve, like in your toilet. They can get stuck, or just plain go bad. If it is overfilling, you need a new valve. Quote Link to comment Share on other sites More sharing options...
Watters Posted May 5, 2020 Author Report Share Posted May 5, 2020 the issue is the pool will not auto fill. Is this s threaded at the base? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 6, 2020 Report Share Posted May 6, 2020 Oh, your title said overflow. What is the blue tape wrapped pipe thingy in your pic? I would think it would unscrew. It should also have another valve to turn it off for winterization. Do you know where that is? Quote Link to comment Share on other sites More sharing options...
Watters Posted May 6, 2020 Author Report Share Posted May 6, 2020 No clue as to the blue tape. I do not know where the winterization valve would be. Is this to shut off water supply to auto fill? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 6, 2020 Report Share Posted May 6, 2020 Yes. And your autofill pipe is probably 1" or 3/4" pipe, like the one wrapped in blue tape. I suspect it is just turned off somewhere. They could not leave it on when the pool was closed. Quote Link to comment Share on other sites More sharing options...
