Craig C Posted April 17, 2020 Report Share Posted April 17, 2020 Good afternoon I have a Lay z Spa Hawaii hot tub, excellent piece of kit for the relatively low price. one thing that lets it down is the filter. I have found that keeping the water clear is hard, we take all the precautions, I.e. shower before use etc. But the water gets cloudy easy, I keep on top of the filters, chlorine kept correct levels. As a last attempt I have ordered some Clearwater fluid from eBay to see if this helps. just wondering is their a small external filter unit that I can purchase to run alongside the existing filter unit to keep on top of it, or shall I take a different approach. thanks in advance. Good afternoon I have a Lay z Spa Hawaii hot tub, excellent piece of kit for the relatively low price. one thing that lets it down is the filter. I have found that keeping the water clear is hard, we take all the precautions, I.e. shower before use etc. But the water gets cloudy easy, I keep on top of the filters, chlorine kept correct levels. As a last attempt I have ordered some Clearwater fluid from eBay to see if this helps. just wondering is their a small external filter unit that I can purchase to run alongside the existing filter unit to keep on top of it, or shall I take a different approach. thanks in advance. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 17, 2020 Report Share Posted April 17, 2020 Sorry Craig, I couldn't begin to tell you. I know that from all the unresolved threads I have seen about them, I would not even recommend one to my brother-in-law, whom I can't stand. Best of luck. Quote Link to comment Share on other sites More sharing options...
Craig C Posted April 17, 2020 Author Report Share Posted April 17, 2020 Thanks RD, everything about the tub is great, just the filter side takes a bit of keeping on top of. They should upgrade the filter side to be a bit bigger. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 18, 2020 Report Share Posted April 18, 2020 I am happy it is working good for you. If you peruse the recent posts, you will see many la-z-spa threads about problems that remain unresolved. The same is true on the other forum I frequent. It seems that parts are nearly impossible to get, and even getting into it to troubleshoot is an ordeal. Quote Link to comment Share on other sites More sharing options...
Linds Posted April 18, 2020 Report Share Posted April 18, 2020 Hi, do you regularly ‘shock’ your water? Quote Link to comment Share on other sites More sharing options...
