Clouds on use
Oppyusa
I just started a Coleman Saluspa.  While everything is in balance and clear pre-use, the spa gets milky after use.  If I wait two days and do nothing, it clears up.  Use it again, and it clouds.  Where should I look for solutions?
Sorry if this is  the wrong spot for the question
2 hours ago, RDspaguy said:
What are your readings? What are you using in it?
Based on his description, it almost sounds to me like calcium carbonate precipitation from a low PH..... but  I've only encountered that once in my life in a hotel complex with a poorly maintained pool   Then again, what the heck do I know - I'm still a fascinated newbie soaking up knowledge lol
