Crushed pipe
Johnmmc
Yes you can replace a piece of plumbing but how easy/difficult it will be is hard to know without seeing a picture.  All 1.5" and 2" plumbing is glued, no exceptions.  As long as the part that needs replacement is not near a manifold or elbow, then it shouldn't be too bad.  You would essentially cut out the crushed section and then glue in a new section using two external connectors that will slip over the plumbing, sometimes called magic menders.
