Do I need a wetvac to clean my minispa?
Amayazhi
I have 2 year old 100 gallon hot tub which i bought new. I just started having problems with milky water from the jets (apparently because I went out of town for two weeks and ignored it, didn't add any MPS). I just used Spa Purge on it and I can't get all of the water out of the filter area. My question is, do I  need to buy a wetvac to clean my hot tub? Or is itok to leave some of the oldwater, even if it has spa purge in it, in the filter area (and I guess also in the lines to the jets?)
Thanks in advance for any suggestions!
To save the cost of buying a wet vac, you could spray water full force into the jets, which will help clean out the plumbing. You can also refill the tub, which will dilute the two or three gallons left in the plumbing.  If you still feel it's dirty, drain and refill.
Unless you're in a drought area with water restrictions, it all depends on what's less work and what's less expensive -- 100 gallons of water or a wet vac?
  • 3 weeks later...
