Amayazhi Posted July 21, 2017 Report Share Posted July 21, 2017 I have 2 year old 100 gallon hot tub which i bought new. I just started having problems with milky water from the jets (apparently because I went out of town for two weeks and ignored it, didn't add any MPS). I just used Spa Purge on it and I can't get all of the water out of the filter area. My question is, do I need to buy a wetvac to clean my hot tub? Or is itok to leave some of the oldwater, even if it has spa purge in it, in the filter area (and I guess also in the lines to the jets?) Thanks in advance for any suggestions! Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted July 22, 2017 Report Share Posted July 22, 2017 To save the cost of buying a wet vac, you could spray water full force into the jets, which will help clean out the plumbing. You can also refill the tub, which will dilute the two or three gallons left in the plumbing. If you still feel it's dirty, drain and refill. Unless you're in a drought area with water restrictions, it all depends on what's less work and what's less expensive -- 100 gallons of water or a wet vac? Quote Link to comment Share on other sites More sharing options...
Amayazhi Posted August 12, 2017 Author Report Share Posted August 12, 2017 Thank you! Quote Link to comment Share on other sites More sharing options...
