NateStreeter Posted July 16, 2017 Report Share Posted July 16, 2017 Opened up hot tub to find that water was down over a foot. Here is video I made: Opened up cover and found leak at the heater. Also looks like there is white build up on it. Will I be needing to replace whole heater assembly? P.S. The LED lights don't work right at all. At first a few started to not work after like a year. Then a few used to stay on all the time and controls didn't do anything. Now none come on. Is that something that is an easy fix while I have this all open? Quote Link to comment Share on other sites More sharing options...
jeremyh Posted July 20, 2017 Report Share Posted July 20, 2017 Chemical abuse or freeze damage is all I've seen cause that. Since you mention white build up, I am leaning too chems. Yes you need a new heating assembly. Quote Link to comment Share on other sites More sharing options...
NateStreeter Posted July 20, 2017 Author Report Share Posted July 20, 2017 We usually put in several tablespoons of chlorine once or twice a week. With water changes once or twice a year. Perhaps that has created this problem, as we don't do any water testing or anything? We are in Minneapolis, with some of the best tap water quality in nation----so I didn't think much else would be required. Quote Link to comment Share on other sites More sharing options...
NateStreeter Posted July 22, 2017 Author Report Share Posted July 22, 2017 Ok I've taken it apart. Looks like there is a crack in the plastic at the end of the heater where it does the loop. Is this repairable? https://www.dropbox.com/s/csr7vp2flswiv1h/2017-07-22 14.23.15.jpg?dl=0 https://www.dropbox.com/s/ijfisxcu333td87/2017-07-22 14.22.53.jpg?dl=0 Quote Link to comment Share on other sites More sharing options...
Mark Murphy Posted December 13, 2018 Report Share Posted December 13, 2018 What did you do ultimately to resolve the leak problem in the heater? I have a leak at the opposite end of my heater... in the plastic. You can see the mineral buildup. I really could use a reply. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
NateStreeter Posted December 13, 2018 Author Report Share Posted December 13, 2018 I am using just chlorine in my spa now. I ended up buying a new heater on Ebay. You can buy the gaskets if the plastic isn't cracked. There are now more repair parts that you can find there: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR3.TRC0.A0.H0.Xwatkins+heater.TRS0&_nkw=watkins+heater&_sacat=0 Quote Link to comment Share on other sites More sharing options...
Mark Murphy Posted December 13, 2018 Report Share Posted December 13, 2018 Many thanks! I'll check into that. Mark Quote Link to comment Share on other sites More sharing options...
alaska_guy Posted January 3, 2019 Report Share Posted January 3, 2019 White is also more than likely due to mineral buildup/scale. If you are not using a water purifier/filter on your garden hose when filling up the tub I would look into doing that. They are cheap and reusable ($13). Quote Link to comment Share on other sites More sharing options...
