dg98adams Posted September 16, 2015 Report Share Posted September 16, 2015 I am reassembing my hot tub pumps & heater pipe... it's been apart for a while. The rings and the flangeas have O-rings or seals on the lip. I want to clean the o-rings and flange seals and lubricate them before assembly. So for O-ring lube, i know you don't use Vaseline or any petrolem product... but all I have found in the O-ring section at my local supply store is either "Water Proofe grease" or " Silicone grease"... I did not find anything that specifically said "O-ring lube". When I did searches on "O-ring" lubricant, mostly I hit Silicon-based as the preferred lube... especially for Pool and Spa. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted September 16, 2015 Report Share Posted September 16, 2015 http://www.amazon.com/Aladdin-Magic-Teflon-Lubricant-Sealant/dp/B0039ZE2HK Quote Link to comment Share on other sites More sharing options...
