pkillur Posted June 4, 2015 Report Share Posted June 4, 2015 I have a Windriver spa that uses a Balboa Spa Pack. The exact model escapes me but it's around 2001(ish). We've had a ton of rain lately and I'm assuming a short of some sort (I live in Denver, and it almost never rains). The circ pump is no longer running, and when I push the button for pump 1 and pump 2 it turns on the light like it's running but doesn't do anything. As the circ pump isn't working, it's obviously not heating (Thank God it's not negative 10 outside!!!) Can any of you think of something simple that could be wrong with the spa pack that is easily remedied or is it probably fried? Thanks in advance Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 5, 2015 Report Share Posted June 5, 2015 When the cpu is acting a little schitzo- it usually needs replacement. However, it may have just gotten wet, and it may dry out. Quote Link to comment Share on other sites More sharing options...
pkillur Posted June 5, 2015 Author Report Share Posted June 5, 2015 When the cpu is acting a little schitzo- it usually needs replacement. However, it may have just gotten wet, and it may dry out. So if I get a comparable kit it should work I'm guessing? Are there any reasons to leave balboa and go to another brand that might be better / less expensive?? Quote Link to comment Share on other sites More sharing options...
