Tsco Posted November 23, 2014 Report Share Posted November 23, 2014 In addition to the auto fill valve able to fill a pool to the desired level..can it also drain to a desired level? I ask this because my pool's level became too high so I lowered the auto fill level..for the past three days my street drain has been steadily trickling a small amount of water..the only place it could come from is my pool; but I am unsure that it is the auto fill draining vice a leak. My pool is only 17 months old (gunite with pebble tec); so I would like to think that it isn't leaking! My auto fill is a Paramount Paralevel. Any thoughts would be appreciated! Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted December 1, 2014 Report Share Posted December 1, 2014 An overflow line can be incorporated into this unit. I suppose you would either have to investigate this yourself (visually in the can), or ask your pool builder if he used that option on the auto filler. http://www.1paramount.com/products/paralevel/ Quote Link to comment Share on other sites More sharing options...
stevenz1g Posted December 13, 2014 Report Share Posted December 13, 2014 Essentially what spa guru said ^. Most autofills will have a drain port near the top of the casing to prevent serious overflows going into yard and what. Are you 120% positive that the pool is the only thing routed to your street drain? Do some inspections... go to your autofill and see if you hear any water bypassing an o-ring it shouldn't be. Shut the fill line OFF to your autofill for a week or so and see if that alleviates the problem. Quote Link to comment Share on other sites More sharing options...
