Spark From Circuit Board
I have a balboa el8000 mach 2 circuit board that has sparked and semi melted the board around 1 of the 2 contacts for the heating element. Can it be repaired or do I need to replace? And what would have caused this. Everything is still intact but you can see where it fried a little
The heater probably caused this damage due to a ground fault. Your GFCI needs to be tested as well. The board can be repaired if the board and circuit traces are not compromised. Otherwise, just replace the board.
John
The most common causes for premature heater element failure by newbs is either not fully sealing the bulkhead gasket or, more commonly, damaging the ceramic seal around the cold pins. Check for signs of hairline cracks to one or both cold pin ceramic seals from twisting the cold pin.
John
