chazman113 Posted November 8, 2012 Report Share Posted November 8, 2012 Just bought a used hot springs prodigy 110v tub (1996 or 1997 manufactured I believe) in awesome shape. I want to use the filter frog mineral system so I can put less bromine in the system (sensitive skin). The tub has a filter box with 3 filters that have pipes coming up to secure each filter. Obviously can't "stick" a filter frog in there because of the pipes. It has a small pump that I believe runs 24/7 to filter and heat and seems to have input in one of the 3 filter cartridges. My question is, can I just rubber band the filter frog to the side of the filter and have it work correctly? According to the manual it says you can just put them in the skimmer box, but also says it's for larger pumps. Maybe I'm overthinking it. PS I know there is a spa frog "floating" system but I just bought a supply of bromine and a floater so want to use that up first Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 11, 2012 Report Share Posted November 11, 2012 It won't really allow "less bromine" in actual use if you want to maintain sanitized water. If you have sensitive skin I would NOT use MPS to shock the tub, stick with chlroine for shocking. MPS is a known irritant. Quote Link to comment Share on other sites More sharing options...
