Hot Springs Vanguard Kicks 20 Amp Breaker
wydopn15
bought used vanguard 2003 finally got it hooked up replaced spa disconnect as my oold tub was straight 50 amp bought box from dealer hooked everything by the book checked and rechecked wiring flipped on main and gfcis red light flashed kicked 20 amp out right away and now won't reset rechecked wiring every thing looks right but won't reset turned of main reset gfci's flipped main on kicks 20 immediatly any ideas well help my guess is bad breaker but is brand new but spa well not do anything very frusterating
The white wire from the spa should go to the breaker, NOT the neutral lug.
B)
