I Need Help On My In Floor System
I resently cleared my memory on the display to add my own programs and now my in floor system is not turning on , I went on system setup then in floor cln and turned it on and nothing but I also noticed my filter pump has 20 lbs is pressure way above normal if I clean my filter will that turn it on
RS-6 was what I needed.
Sounds like the valve actuator isn't programmed. I would expect it to be #3. Label it in the RS and assign it a time period when the pump is on.
Scott
