Bullfrog Model 70 2003 Model
trialsguy
I have inherited a spa from the inlaws in hopes that I can figure out whats wrong with it without spending too much dough on it.
I have voltage to the main board but no operation, no lights or activity in the touch pad up top. I can hear a slight hum which I think tells me the small transformer is powered up. I have tested all the small glass fuses and all test good.
I have various voltages through out the board.
I would like to know if there is a way to "jumper" around the touch pad control up top to either rule it as a problem or verifiy that it is working properly.
I have a good understanding of control boards and their operation what I am looking for is a way to pinpoint the problem without just throwing parts at it until it works.
Thanks a bunch
Bob
Bob,
Here is a link to the owner's manual for your spa:
http://bullfrogspapa...rs-manual-2003/
Here is a link to our toubleshooting guide:
http://bullfrogspapa...-bullfrog-spas/
Basically, you can unhook the control pad (and auxillary pump contols if equipped) and the spa should startup and run all by itself. If it does not, then you probably have a board issue. Here is the replacement BULF70 board:
http://bullfrogspapa...product=7655714
Hope this helps.
The Spa Master
