103TUB Posted February 28, 2012 Report Share Posted February 28, 2012 We have a 2001 Sundance Altamar. I replaced the circ pump again yesterday, it was not running and I had the FLO message. The only time the pump runs is when it is heating. I have the owners manual and I followed the instructions to change the program to run 24 hours, but it does not change anything. The other programing is in the standard mode and the panel in not locked. We have had this tub since new and the circ pump running has always seemed like it has a mind of it's own. This is the first time I have tried to program the circ pump. Am I missing something? Thanks Quote Link to comment Share on other sites More sharing options...
n1oty Posted February 29, 2012 Report Share Posted February 29, 2012 Once you set for continuous circ pump operation, the time must go past midnight before that logic takes over. Check it the following day. If it still is not working correctly, you probably have a board issue or a time chip issue. John Quote Link to comment Share on other sites More sharing options...
JAMES THE HOT TUB GUY Posted February 29, 2012 Report Share Posted February 29, 2012 I can help contact me premierhottubs@etcmail.com Quote Link to comment Share on other sites More sharing options...
103TUB Posted March 1, 2012 Author Report Share Posted March 1, 2012 Thank you John and James. You were right, today the circ pump is running all the time. Time will tell if it stays that way. Quote Link to comment Share on other sites More sharing options...
