partyboy Posted April 5, 2011 Report Share Posted April 5, 2011 I am running 3 part bromine with little problems. I have 380 gallons running filter/ozone cycle for 4 hrs a day. I keep the bromine levels at 4ppm with the floater and this is relatively easy. I will add a little MPS or bleach during partys/high bather loads and after if levels drop lower than usual. The problem: I can't easily test CD in my bromine system since the floater is always in. My MPS bottle suggests I shock 1x a week at a dose that makes my bromine shoot up past 20ppm for a couple of days rendering my tub unusable. If I don't shock for a few weeks I will have to open the floater to maintain the bromine level. In my mind this means it is time for a shock. Question: I can easily make changes to the amount of MPS or bleach I add when doing a shock to get the desired bromine level. What is the required level in ppm for a maintenance shock? Should I shock weekly or just when I find myself having to open up the floater to keep up? I'm seriously considering dichlor/bleach because I don't like the 2 day wait after oxidizing my tub. Quote Link to comment Share on other sites More sharing options...
waterbear Posted April 5, 2011 Report Share Posted April 5, 2011 Stop the MPS and start using liquid chlorine for oxidizing. Quote Link to comment Share on other sites More sharing options...
waterbear Posted April 5, 2011 Report Share Posted April 5, 2011 I The problem: I can't easily test CD in my bromine system since the floater is always in. What is CD? Quote Link to comment Share on other sites More sharing options...
partyboy Posted April 5, 2011 Author Report Share Posted April 5, 2011 I The problem: I can't easily test CD in my bromine system since the floater is always in. What is CD? I guess It's not Chlorine Demand, but more like Bromine Demand. I was referring to how much sanitizer the tub uses in a 24 hr period. Any ideas on how often a shock is really needed with bromine and how to tell? I think weekly is overdoing it when its usually just me soaking. Quote Link to comment Share on other sites More sharing options...
partyboy Posted April 5, 2011 Author Report Share Posted April 5, 2011 any ideas on the ideal ppm bromine to shoot for when shocking? I have read as little as 10ppm is sufficient but would prefer a second opinion. Quote Link to comment Share on other sites More sharing options...
Itchy and Scratchy Posted April 5, 2011 Report Share Posted April 5, 2011 My weekly MPS shocks bump the test reading up around 15 ppm. If I shock it in the morning it will be around 8 ppm that evening. Anything below 10 ppm is ok to enter. My tub is under 200 gallons and I use it 1 hour every night. After my soak I usually add 1 to 2 tablespoons of bleach to help oxidize my waste, I have ozone as well. Hope that helps ya. Quote Link to comment Share on other sites More sharing options...
waterbear Posted April 5, 2011 Report Share Posted April 5, 2011 You are really making bromine a lot harder than it is. Here is how to do bromine. Read it again. It answers all your questions! If the amount of oxidizer you are adding is raising your bromine above 20 ppm then use less when you shock! It's pretty easy really. Try half the amount you are using. If you get it above 10 ppm you are fine. Keep the tub uncovered AND all the jets and aerators running after shocking and you should find the bromine level drops down fairly quickly. Quote Link to comment Share on other sites More sharing options...
partyboy Posted April 6, 2011 Author Report Share Posted April 6, 2011 Itchy and Scratchy: thanks for your input. Your real-world experience was what I was looking for. I can deal with 1/2 day waiting for the bromine levels to come down, just not 1.5-2 days as it has been taking. Waterbear: I probably am over-thinking this a bit. That happens when my OC disorder kicks in. I recently ran out of MPS and will be using only bleach to shock. It shouldn't be hard to learn how much it takes to get to approx. 15ppm bromine. Thank you both for your help. Quote Link to comment Share on other sites More sharing options...
Itchy and Scratchy Posted April 6, 2011 Report Share Posted April 6, 2011 If you keep your bromine level at 4 ppm check it after your soak. Mine drops to 2 ppm, I add a tablespoon a bleach to bump it back to 4 ppm. Many variable depending on bromine bank and oragaic waste. Just experiment with your Taylor test kit and you will have your routine down in no time. Quote Link to comment Share on other sites More sharing options...
