Pump Will Not Stop!
Chuck L
I have an older (I believe that it is a late 90's model) Cal Spa 3 man hot tub. We got it free and installed it about 3 months ago.
Up until now, everything has operated satisfactorily (installed new heater element, repaired a few jets, etc). However...now the pump will not shut off! It is (as, I believe, most are) controlled by a vacuum/pressure switch for the on/off as well as an adjustable pressure air intake.
Is this, possibly, caused by a defective pressure switch or am I looking at something a bit more involved (and costly)?
Any input would be greatly appreciated!
Chuck
more detail, is it staying on low or high speed, If its cold out, and the tub is calling for heat, the pump will stay running on low. be more describtive and what have you tried?
