gkm Posted May 15, 2010 Report Share Posted May 15, 2010 I have an issue w/ my 2-speed pump in that it starts and runs for 0.5 seconds, kicks off and restarts once the thermal resistor resets. I took the pump off and hooked it to 240v and it works perfectly on low and high speed. I also pulled the comp. board and there's no burnt connections that I can determine. The circ pump, heater and 1-speed pump work fine as well as the panel. There are no error codes on the control panel. I forgot to mention that the tub is a 2003 Sundance Altamar. Any/all advise would be greatly appreciated. Regards, Greg Quote Link to comment Share on other sites More sharing options...
gkm Posted May 15, 2010 Author Report Share Posted May 15, 2010 Ok, now I'm really baffled! I switched the 2-speed pump connections on the board to the 1-speed pump terminals. The pump works fine on the 1-speed terminals. So, I reconnected to the two-speed pump connections and disconnected the red (high speed) and it works fine. It also works fine w/ just the low (black) connected; however, when all three wires are connected to the terminals, the pump will trip its thermal resistor. I'm at a loss as this doesn't make sense, other than somewhere on the board there's an issue. Maybe time for a new board?? Quote Link to comment Share on other sites More sharing options...
ChaiSTi Posted May 21, 2010 Report Share Posted May 21, 2010 Check the relays to see if they are supplying voltage to the low or high speed when not called for. You could have a stuck relay. Quote Link to comment Share on other sites More sharing options...
JAMES THE HOT TUB GUY Posted May 24, 2010 Report Share Posted May 24, 2010 Check the relays to see if they are supplying voltage to the low or high speed when not called for. You could have a stuck relay. Email me your phone number so i can call you premierhottubs@etcmail.com Quote Link to comment Share on other sites More sharing options...
