baxter Posted May 5, 2010 Report Share Posted May 5, 2010 Wondering the value of a hot springs grandee that was bought new in march 04 Thanks Quote Link to comment Share on other sites More sharing options...
Puckyhuddle Posted May 5, 2010 Report Share Posted May 5, 2010 Wondering the value of a hot springs grandee that was bought new in march 04 Thanks Like anything else, it all depends on the condition, which you don't mention. Quote Link to comment Share on other sites More sharing options...
JerimiahR Posted May 5, 2010 Report Share Posted May 5, 2010 Much like checking the Kelly Blue Book value of a car, there are a lot of determining factors. Value changes from market to market (a Grandee in Alaska is probably worth more than Arizona where folks don't need more heat). The over all condition of the spa (functions or not, leaks or not, new cover, old heavy tattered cover, etc) will play into this. Any accessory items (cover lifter system, ozone, steps, etc) can change the over all value as well. The other thing to consider is: Are you selling? Or buying? If you're buying, make sure you can see it filled with water, heated, and play with the jets. Make sure there are no wet areas around the hot tub. Quote Link to comment Share on other sites More sharing options...
baxter Posted May 5, 2010 Author Report Share Posted May 5, 2010 The tub has been used outside all the time. South Dakota in fact. Cover has some tearing along each end in the middle where the seam is. All jets work, heater replaced last year. Quote Link to comment Share on other sites More sharing options...
