poolmama Posted April 20, 2010 Report Share Posted April 20, 2010 Back in December a noticed some white spots growing on my pool. We have a 2yr old Marbelite indoor Pool. They got bigger even after we scraped them off. Now I've got them all over, small ones, big ones...tiny ones. Can someone tell me what's happening?? Quote Link to comment Share on other sites More sharing options...
PaulR Posted April 21, 2010 Report Share Posted April 21, 2010 Possibly calcium scaling. What are your water test results? especially pH, Total Alkalinity, and Calcium Hardness. What kind of chlorine do you use? If it's calcium hypochlorite (typically comes as 1-lb bags of powder) that's probably contributing to the problem. --paulr Quote Link to comment Share on other sites More sharing options...
poolmama Posted April 21, 2010 Author Report Share Posted April 21, 2010 Possibly calcium scaling. What are your water test results? especially pH, Total Alkalinity, and Calcium Hardness. What kind of chlorine do you use? If it's calcium hypochlorite (typically comes as 1-lb bags of powder) that's probably contributing to the problem. --paulr Quote Link to comment Share on other sites More sharing options...
poolmama Posted April 21, 2010 Author Report Share Posted April 21, 2010 Possibly calcium scaling. What are your water test results? especially pH, Total Alkalinity, and Calcium Hardness. What kind of chlorine do you use? If it's calcium hypochlorite (typically comes as 1-lb bags of powder) that's probably contributing to the problem. --paulr Thanks paulr, alkalinity was low for a really long time, I realized that they were using chlorinated pucks. It's an indoor pool. So we dumped the pool and got the cynaric acid down to 50 and have been able to keep the alkalinity around 110 now. While this was going on, we only had these 3-4 large ones...now evrything is perfect and i have deposits every where. This is not around the edge of the pool, but in it. from the bottom of the pool to just below the surface. from the deep end all the way to the shallow end. When i made them get rid of the pucks we went to liquid chlorine on a stenner pump. PH 7.4-7.6, calcium 280-320, fc 2,alkalinity 110, cyanaric acid 50 Quote Link to comment Share on other sites More sharing options...
