tloftus Posted March 29, 2010 Report Share Posted March 29, 2010 Is it possible to convert a 1993 Hot Spring Soverign to run off of a 220V service? I think doing so should allow the heater and jet pump to run at the same time. If so, does anyone have a diagram or written instruction on doing so? Thanks, Tom Quote Link to comment Share on other sites More sharing options...
ps558 Posted March 29, 2010 Report Share Posted March 29, 2010 Is it possible to convert a 1993 Hot Spring Soverign to run off of a 220V service? I think doing so should allow the heater and jet pump to run at the same time. If so, does anyone have a diagram or written instruction on doing so? Thanks, Tom According to my info yes it can be setip to run on 230 volts. They don't list a diagram online for that spa, but sometimes there is one located on the back side of control box cover. try calling watkins at 1-800-999-4688 follow prompts to tech support Quote Link to comment Share on other sites More sharing options...
tloftus Posted March 29, 2010 Author Report Share Posted March 29, 2010 According to my info yes it can be setip to run on 230 volts. They don't list a diagram online for that spa, but sometimes there is one located on the back side of control box cover. try calling watkins at 1-800-999-4688 follow prompts to tech support There is nothing on either side of the cover and I can't get anyone to answer at that 800# Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted March 30, 2010 Report Share Posted March 30, 2010 As far as I know you CANNOT convert a pre-1997 HotSpring to 230 Volts. They pre-wired and sold them as strictly 230 volt units back then. Quote Link to comment Share on other sites More sharing options...
