kbaumann Posted February 1, 2010 Report Share Posted February 1, 2010 Best bromine tabs to use? Quote Link to comment Share on other sites More sharing options...
kbaumann Posted February 5, 2010 Author Report Share Posted February 5, 2010 No responces????? wow =( Quote Link to comment Share on other sites More sharing options...
chem geek Posted February 5, 2010 Report Share Posted February 5, 2010 I know that Hillbilly Hot Tub prefers DBDMH (more unusual dibromo tablets) as noted in this thread since it does not smell as much as when using BCDMH (more typical bromo-chloro combination tablets). Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted February 5, 2010 Report Share Posted February 5, 2010 I know that Hillbilly Hot Tub prefers DBDMH (more unusual dibromo tablets) as noted in this thread since it does not smell as much as when using BCDMH (more typical bromo-chloro combination tablets). Yes I do, Brilliance has a form that has no chlorine, they are chunks not tablets, and sea klear has tablets that are a blend, but it is 64.9% bromine/29% chlorine rather than most other tablets that are39.2% bromine/44.4 % chlorine......notice they others are mostly chlorine. The is a dramatic difference in the smell, and you use much less of the higher bromine product(you can turn the feeder fairly low) as long as you shock consistantly. Quote Link to comment Share on other sites More sharing options...
