Jbuck Posted December 29, 2009 Report Share Posted December 29, 2009 After helping a couple of my neighbors install an outdoor wood furnace for home heating I have decided to invest in one myself. All the furnace information I can locate on the net indicates you can heat your swimming pool and/or hot with them. Anyone using a wood furnace for heating their hot tub, if so how is it working for you? Quote Link to comment Share on other sites More sharing options...
dirtrider Posted December 30, 2009 Report Share Posted December 30, 2009 After helping a couple of my neighbors install an outdoor wood furnace for home heating I have decided to invest in one myself. All the furnace information I can locate on the net indicates you can heat your swimming pool and/or hot with them. Anyone using a wood furnace for heating their hot tub, if so how is it working for you? It's working perfectly. I did all the work myself. Ended up being able to set the temp on the hot tub as normal through controller. As a user, there is NO WAY you can tell if it's being heated by the OWB or electric. Just a "flick" of a switch changes between the two. We keep it at 104 with no electric needed for heat Here's a little thread I had on it: http://www.poolspaforum.com/forum/index.ph...wb+heat+hot+tub Any questions, ask away. Quote Link to comment Share on other sites More sharing options...
