Thanks for the reply,
OK, a little better description
On my tub, I have what looks to be a 2" (may be larger) line coming from my filters directly to my heater, it comes out of the heater and goes to a pump I haven't pulled that side off, but coming back from that side is a 1 to 1.5" hose going back into my tub which is from the 24/7 circulator pump. This is also where the hot water comes into the tub when the jet pumps are off. The heat exchanger will be just before where it dumps into the tub now. I will not be restricting anything to my heater, or controls, nor any water flow when all pumps and jets are running. The heat exchanger has a flow rate of 44.9 gals a minute so a restricted flow is a non issue. It is also designed for "chemically treated" water. I am very knowledgeable on automotive and equipment hydraulic, electrical AC/DC, spraying, engine, transmission.......systems but I just could find no "technical" info on the probes. I did call where I got the tub, the tech guy was pretty sure that I would be OK but wouldn't give me a definate "yes" answer.
I already know I can heat withn an external heat exchanger (I have already seen one in operation) but it uses an independant thermostat, temp probe, relay, and transformer to operate. I am looking to take that set up one step further and use the existing temp control.
The answer about the probes (my original question) that they should not be affected by NOT (water coming into and out of heater will be "same" temp) seeing a difference between them is the "same" answer I did get from the dealer Tech I spoke with. So, 2 independent same answers is good for me
I going to give a shot. I won't be firing up the OWB till October but I will definately post back how it worked (or not worked )
Thanks again and any other comments are surely welcome.
