dhp78 Posted November 1, 2009 Report Share Posted November 1, 2009 I am trying to hook up an ozone generator in our spa. It is mounted and wired and ready to go except for the ozone tube. Can some one tell me where to hook up the ozone tube on a Bullfrog 331. Is there an existing port that I can connect the tube to, or will I have to install a fitting? If I have to install the fitting, what is the best location for it? Thanks. Quote Link to comment Share on other sites More sharing options...
lkneisler Posted November 3, 2009 Report Share Posted November 3, 2009 Your spa may be "ozone ready" where there is a clear tube to connect to using a check valve. Sometimes it's obvious, sometimes it's mostly buried in the sprayed on insulation/foam. In any case, it would be in the equipment area near the access panel. If it's not ozone ready then this might help: http://www.hottubessentials.com/installing_ozonators.htm It's a little over-complicated but it has diagrams and examples and we're told it's useful. Quote Link to comment Share on other sites More sharing options...
