ytsejam Posted September 1, 2009 Report Share Posted September 1, 2009 Hello all, I just got done resurecting a 92 Tiger River Spa's Manora. It's a 115Volt unit. I replaced the circuit board, High Limit switch and heater element. Everything works now but the tub won't get above 86°F. The t-stat is turned up all the way and the cover is on. It's been plugged in for 48hours and hasn't gone up at all since last night. Any suggestions? I was going to break out my amp meter just to verify the heater is still being commanded on but it's dark now. Anyone have any experience with these tubs? Thanks Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted September 1, 2009 Report Share Posted September 1, 2009 Hello all, I just got done resurecting a 92 Tiger River Spa's Manora. It's a 115Volt unit. I replaced the circuit board, High Limit switch and heater element. Everything works now but the tub won't get above 86°F. The t-stat is turned up all the way and the cover is on. It's been plugged in for 48hours and hasn't gone up at all since last night. Any suggestions? I was going to break out my amp meter just to verify the heater is still being commanded on but it's dark now. Anyone have any experience with these tubs? Thanks Are you sure it's 86 degrees? Just making sure...I've had people tell me their tub was 65 degrees because the thermometer said so even thought it was 102. If so, I would suspect the t-stat. Like you suggested, you may need to test the amperage and do some metering. Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted September 3, 2009 Report Share Posted September 3, 2009 That spa has a reset by turning down and up the t-stat. You might try this in case it tripped. Quote Link to comment Share on other sites More sharing options...
