njcowboy Posted August 24, 2009 Report Share Posted August 24, 2009 The water in the spa is about 3 weeks old. I was using a spa frog with bromine and the mineral insert. Bromine has been low and hardness is low, but PH, alkalinity CYA are all in line. I have been hesitant to put in the chemicals to raise the hardness because it is a milky mixture that will only add to the cloudiness. I have added a second floater for Bromine and now the level is showing at 2.5 PPM for bromine. The filter is new I use Spa Clear and Perfect once a week and a capful of oxidizing shock after each use. Any ideas on how to get the tub clear? Quote Link to comment Share on other sites More sharing options...
njcowboy Posted August 24, 2009 Author Report Share Posted August 24, 2009 The water in the spa is about 3 weeks old. I was using a spa frog with bromine and the mineral insert. Bromine has been low and hardness is low, but PH, alkalinity CYA are all in line. I have been hesitant to put in the chemicals to raise the hardness because it is a milky mixture that will only add to the cloudiness. I have added a second floater for Bromine and now the level is showing at 2.5 PPM for bromine. The filter is new I use Spa Clear and Perfect once a week and a capful of oxidizing shock after each use. Any ideas on how to get the tub clear? Sorry, Wrong forum. Quote Link to comment Share on other sites More sharing options...
