RuBaDuB Posted June 27, 2009 Report Share Posted June 27, 2009 Hi all, in the footwell of my Coyote Spas Drifter, there is a large (3" diameter x 3" long or so) metal screen cover over something and I'm curious as to what this is. Nothing seems to go in or out of it. Other things in the footwell are jets, blower air outlets, ozone outlet, drain and lights...what else is left that this metal screen thingy could be, or be covering? It doesn't seem to do anything. Thanks. Quote Link to comment Share on other sites More sharing options...
Roger Posted June 27, 2009 Report Share Posted June 27, 2009 Hi all, in the footwell of my Coyote Spas Drifter, there is a large (3" diameter x 3" long or so) metal screen cover over something and I'm curious as to what this is. Nothing seems to go in or out of it. Other things in the footwell are jets, blower air outlets, ozone outlet, drain and lights...what else is left that this metal screen thingy could be, or be covering? It doesn't seem to do anything. Thanks. Maybe theres a 2 pump model of your tub that needs a suction where this screen is. Quote Link to comment Share on other sites More sharing options...
imnay Posted June 27, 2009 Report Share Posted June 27, 2009 Hi all, in the footwell of my Coyote Spas Drifter, there is a large (3" diameter x 3" long or so) metal screen cover over something and I'm curious as to what this is. Nothing seems to go in or out of it. Other things in the footwell are jets, blower air outlets, ozone outlet, drain and lights...what else is left that this metal screen thingy could be, or be covering? It doesn't seem to do anything. Thanks. Maybe theres a 2 pump model of your tub that needs a suction where this screen is. Some main jet pumps (like ours) exhaust heat out of the motor compartment through a flexible exhaust hose to our outlet at the bottom of the spa. Quote Link to comment Share on other sites More sharing options...
paulmn Posted June 27, 2009 Report Share Posted June 27, 2009 Hi all, in the footwell of my Coyote Spas Drifter, there is a large (3" diameter x 3" long or so) metal screen cover over something and I'm curious as to what this is. Nothing seems to go in or out of it. Other things in the footwell are jets, blower air outlets, ozone outlet, drain and lights...what else is left that this metal screen thingy could be, or be covering? It doesn't seem to do anything. Thanks. Maybe theres a 2 pump model of your tub that needs a suction where this screen is. Some main jet pumps (like ours) exhaust heat out of the motor compartment through a flexible exhaust hose to our outlet at the bottom of the spa. Hopefully there's nothing wrong with your Coyote. You could contact the factory or the dealer, one of them might know what it is. Quote Link to comment Share on other sites More sharing options...
RuBaDuB Posted June 27, 2009 Author Report Share Posted June 27, 2009 Dealer says it's a second water intake in addition to the filter, to make sure the jets have maintain good pressure. Quote Link to comment Share on other sites More sharing options...
