bbg Posted June 16, 2009 Report Share Posted June 16, 2009 I have a coastal spa (cool night series) When pumps on high the breaker trips. It doesn't happen right away, usually after 30 seconds to 1 minute. Any ideas bbg Quote Link to comment Share on other sites More sharing options...
Roger Posted June 16, 2009 Report Share Posted June 16, 2009 I have a coastal spa (cool night series) When pumps on high the breaker trips. It doesn't happen right away, usually after 30 seconds to 1 minute. Any ideas bbg The tub is drawing more power than the breaker is rated for. But without that information from we I am only speculating. What is the breaker listed for? What is the spa rated to have? Quote Link to comment Share on other sites More sharing options...
bbg Posted June 16, 2009 Author Report Share Posted June 16, 2009 I have a coastal spa (cool night series) When pumps on high the breaker trips. It doesn't happen right away, usually after 30 seconds to 1 minute. Any ideas bbg The tub is drawing more power than the breaker is rated for. But without that information from we I am only speculating. What is the breaker listed for? What is the spa rated to have? Quote Link to comment Share on other sites More sharing options...
bbg Posted June 16, 2009 Author Report Share Posted June 16, 2009 I have a coastal spa (cool night series) When pumps on high the breaker trips. It doesn't happen right away, usually after 30 seconds to 1 minute. Any ideas bbg The tub is drawing more power than the breaker is rated for. But without that information from we I am only speculating. What is the breaker listed for? What is the spa rated to have? Thanks for your quick response! The spa is a 2005 gulf coast cool night series.It is a Cape Haze single pump with blower. The manual spec is for a 50 amp/gfci with 6/3 wire size. The breaker is a 50 amp GFCI wired with 6/3 wire. The spa ran fine for two months prior to this problem. The spa runs fine on low pump speed,heats up to temp setting, and blower works fine. It trips breaker every time after 30 secs to a min on pump hi speed. Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Pool-newb Posted June 17, 2009 Report Share Posted June 17, 2009 See my answer to your other post. Quote Link to comment Share on other sites More sharing options...
