katzbalger Posted June 7, 2009 Report Share Posted June 7, 2009 I need a replacement light fixture gasket for a Solana Tx tub. I've been searching for hours now and have called at least a half dozen spa stores... all w/ no luck. (Appearently, I'm the only one that has ever had a light fixture leak!) At any rate, no one has a replacement in stock. The replacements on-line only come as a "kit", which includes a lens and nut (which I do not need for $25+ S/H). I understand this fixture is possible manufactured by "Be-lite"... and maybe used in Hotspring tubs as well. The gasket measures 2-1/2" x 3-1/4" and is made of clear or white silicon? Any chance someone here stocks just the gasket? Or knows where to go for a replacement . TIA. Quote Link to comment Share on other sites More sharing options...
ps558 Posted June 7, 2009 Report Share Posted June 7, 2009 I need a replacement light fixture gasket for a Solana Tx tub. I've been searching for hours now and have called at least a half dozen spa stores... all w/ no luck. (Appearently, I'm the only one that has ever had a light fixture leak!) At any rate, no one has a replacement in stock. The replacements on-line only come as a "kit", which includes a lens and nut (which I do not need for $25+ S/H). I understand this fixture is possible manufactured by "Be-lite"... and maybe used in Hotspring tubs as well. The gasket measures 2-1/2" x 3-1/4" and is made of clear or white silicon? Any chance someone here stocks just the gasket? Or knows where to go for a replacement . TIA. All replacement lights I've come with lense, nut, gasket etc as a kit. To make you feel better $25 is a good deal. I retail them from $35.00 and up. Quote Link to comment Share on other sites More sharing options...
