Coleman Spa Heater Not Coming On?
I have a coleman spa and I had it running for a few hours yesterday until I noticed temperture had stopped rising.
when I normally start it, I would hit the breaker then the spa would make a noise as if it were to start up, for a split second. 20 seconds later, the spa would turn on and it would begin heating the water. now, it the heat doesnt seem to be working. I dont hear the second noise that would happen 20 seconds after I start the spa. I touch all the other buttons and they seem to work. can it be a fuse that is bad or could it be the heater element is bad?
  • 2 months later...
i have to add that the "flame" is shown on the panel. but I think I have seen that in the past. I dont know if it means that the heater is definetly not working or not.
Does the jet 1 pump run? Is the spa in economy mode or sleep mode? If the pump runs with good water flow and no error codes on the display, i would look at the heater. when the spa is calling for heat and the pc board is sending voltage to the heater, the heater is bad.
What model is the spa?
