KENNY GUIDO Posted May 16, 2009 Report Share Posted May 16, 2009 I have a coleman spa and I had it running for a few hours yesterday until I noticed temperture had stopped rising. when I normally start it, I would hit the breaker then the spa would make a noise as if it were to start up, for a split second. 20 seconds later, the spa would turn on and it would begin heating the water. now, it the heat doesnt seem to be working. I dont hear the second noise that would happen 20 seconds after I start the spa. I touch all the other buttons and they seem to work. can it be a fuse that is bad or could it be the heater element is bad? Quote Link to comment Share on other sites More sharing options...
KENNY GUIDO Posted May 16, 2009 Author Report Share Posted May 16, 2009 i have to add that the "flame" is shown on the panel. but I think I have seen that in the past. I dont know if it means that the heater is definetly not working or not. Quote Link to comment Share on other sites More sharing options...
tom42 Posted July 28, 2009 Report Share Posted July 28, 2009 did you figure it out? I have a model 70 cooperage and the light wont even come on and no heat!! let me know if you figured it out. Thanks Quote Link to comment Share on other sites More sharing options...
ps558 Posted July 28, 2009 Report Share Posted July 28, 2009 i have to add that the "flame" is shown on the panel. but I think I have seen that in the past. I dont know if it means that the heater is definetly not working or not. Does the jet 1 pump run? Is the spa in economy mode or sleep mode? If the pump runs with good water flow and no error codes on the display, i would look at the heater. when the spa is calling for heat and the pc board is sending voltage to the heater, the heater is bad. What model is the spa? Quote Link to comment Share on other sites More sharing options...
