Cworthy Posted April 22, 2009 Report Share Posted April 22, 2009 I recently was given a very old Beechport spa, and am getting ready to try installing it. I have an 8 X 10 concrete slab where I had planned to place it and build an enclosure. I was hoping to have all the equipment within the enclosure, but some of this stuff seems really big! The label on the water pump says it is a swimming pool pump, 50 amp, Magnetek 1.5 hp, 120/240. The filter housing is more than 24" tall and about 8 inches in diameter. Is this normal? It seems like it truly is big enough for a swimming pool, and made me wonder if it was appropriate for a spa....same for the pump---huge! I was expecting more like 3/4 hp. The heater is a Raytek, 48 amp, manufactured in May of 1988. The air blower seems to be what I would suppose is normal size for a spa. Also, there is something I was told is called a "dryer." It looks kinda like another blower, but has a pvc pipe attached that goes straight up about 3 feet and then does a 180 back down to 3 or 4 inches below the "blower" and I have no idea about its purpose. Hope I don't regret getting into all this---any and all advice greatly appreciated---many thanks! Craig Quote Link to comment Share on other sites More sharing options...
James141 Posted April 23, 2009 Report Share Posted April 23, 2009 Hi Craig, Im kind of new to all this but quite hands on. I have found this site brilliant for finding your way around a hot tub: http://spasupport.com/ It sounds like quite a lot of the kit you have is quite old and probably more for commercial spa/pool use and probably even past their best. It might be worth using the shell and re plumbing with a new spa pack and pumps? Sorry I cant be more help P.s can you post some pics up? Quote Link to comment Share on other sites More sharing options...
Cworthy Posted April 24, 2009 Author Report Share Posted April 24, 2009 Hey, James, thanks very much and I will check out the website you recommended. Hopefully I will get a chance to post a few pics this weekend. Much appreciated! Craig Quote Link to comment Share on other sites More sharing options...
