liderbug Posted March 30, 2009 Report Share Posted March 30, 2009 Sundance Optima 03'. The control panel says the circ pump is set to "Standard" and "24". But the pump only runs when heat is called for. When the tub comes up to temp, 102, the circ pump stops and the panel shows "FLO". At that time the other jet buttons don't work. If I shake the flow T the "FLO" changes to 102 and everything works - except for the 24 hour circulation. I've cleaned the llnes (best I can), when the circ pump IS running I get bubbles all the way across the bottom of the tub. Thoughts????? Thanks Chuck Quote Link to comment Share on other sites More sharing options...
liderbug Posted March 31, 2009 Author Report Share Posted March 31, 2009 Well, it's been running just fine for about 24 hrs now. I'm really thinking the wiring going into the flow switch - is that possible? Or the switch is dirty. I've been looking for just the screw in switch part - not a lot of luck. Quote Link to comment Share on other sites More sharing options...
otis_skywalker Posted April 1, 2009 Report Share Posted April 1, 2009 if it's a solid flo on the screen it's the flow switch. you have to buy the complete switch to replace it. Quote Link to comment Share on other sites More sharing options...
