pipewrench Posted February 15, 2009 Report Share Posted February 15, 2009 Hello, I'm looking for some advice on a project I'd like to hire someone to undertake. We have an ingound, indoor pool that we don't use often. We'd like to turn the room into a rec room that could be used year round. Obviously, we'll need a floor over it. I've spoken to one builder already, and have others lined up to come over and check it out too. The liner is shot, btw. The first builder had an interesting solution to the problem, but said we didn't need to fill in the pool with anything. (He wants to cut into the concrete about 6" and lay galvanized steel flooring across it, and then pour concrete on top to make it level with the existing concrete floor.) I'm worried that if I don't fill in the pool with any type of fill, the dirt/sand will slide due to the water table moving it. Any ideas? Should I fill it in, at least part way to keep the dirt/sand from moving? The pool is 14,000 gallons and would take a tremendous amount of fill to fill it all the way up. (Not to mention the task of getting the fill from the truck to inside the building...) SO, what do you think? Fill it in all the way, part way, or none of the way? Thank you all for your help and advice. Quote Link to comment Share on other sites More sharing options...
ps558 Posted February 15, 2009 Report Share Posted February 15, 2009 Hello, I'm looking for some advice on a project I'd like to hire someone to undertake. We have an ingound, indoor pool that we don't use often. We'd like to turn the room into a rec room that could be used year round. Obviously, we'll need a floor over it. I've spoken to one builder already, and have others lined up to come over and check it out too. The liner is shot, btw. The first builder had an interesting solution to the problem, but said we didn't need to fill in the pool with anything. (He wants to cut into the concrete about 6" and lay galvanized steel flooring across it, and then pour concrete on top to make it level with the existing concrete floor.) I'm worried that if I don't fill in the pool with any type of fill, the dirt/sand will slide due to the water table moving it. Any ideas? Should I fill it in, at least part way to keep the dirt/sand from moving? The pool is 14,000 gallons and would take a tremendous amount of fill to fill it all the way up. (Not to mention the task of getting the fill from the truck to inside the building...) SO, what do you think? Fill it in all the way, part way, or none of the way? Thank you all for your help and advice. I would fill it in. For one there is no way of telling how the pool will hold up being empty and then a floor put over the top. The water pushing against the walls and the fill on the other side help to keep the pool in place. I say help because it can be empty but as you stated if ground water can seep into the pool you can a serious problem with mold etc, not to mention if one of the pool walls shift it could ruin the floor on top. Now your looking at more money to repair. I don't know what a insurance company must say if they find out. Somebody has to have some sort of conveyor system that can move fill just like the ones to do commercials roof, moving brick, pouring concrete. I guess you could fill it will stone somewhat then pour concrete over that to keep the pool walls from moving and the stone would be a drain field, but I am not qualified to make that decision. Quote Link to comment Share on other sites More sharing options...
pipewrench Posted February 15, 2009 Author Report Share Posted February 15, 2009 Thank you for your response. That's how I feel about it, too. I think it should be filled in. Even if it doesn't need to be done, just for peace of mind, it will be worth it. Quote Link to comment Share on other sites More sharing options...
jeff grotte Posted February 24, 2009 Report Share Posted February 24, 2009 Thank you for your response. That's how I feel about it, too. I think it should be filled in. Even if it doesn't need to be done, just for peace of mind, it will be worth it. if you are looking for a moving hard floor go to www.wutpool.com and check it out Quote Link to comment Share on other sites More sharing options...
XtremelyTropical Posted March 12, 2009 Report Share Posted March 12, 2009 I strongly suggest filling it in also. You can't be sure of how well it will hold up if you dont and you definetly don't want to double spend later to fix it. Quote Link to comment Share on other sites More sharing options...
txpoolguy Posted March 13, 2009 Report Share Posted March 13, 2009 If you fill it in, it's a good idea to also drill some large holes thru the bottom of the shell so moisture can escape. I'd recommend an engineered plan, to avoid potential future problems. It might cost a little more up front, but could eliminate a disaster later. Quote Link to comment Share on other sites More sharing options...
AprilH Posted January 17 Report Share Posted January 17 We have the same situation slightly larger indoor pool. I am super curious of the route you took on this project and the cost. Quote Link to comment Share on other sites More sharing options...
