Guest James Posted September 24, 2005 Report Share Posted September 24, 2005 The water in my Hot Tub is clear and tests good with the test strip but when I turn the jets on it clouds up with a million oxygen bubbles.It never used to do this.Any help would be appreciated.None of the Hot tub places seem to know other than dump water, refill, and buy more chemicals. Thanks, James Quote Link to comment Share on other sites More sharing options...
Guest Don Posted September 24, 2005 Report Share Posted September 24, 2005 its normal for water on the softer side to cloud up with bubbles, also if you use "biguinide" sanitizing systems. they use a product that reduces water tension, both of which can be corrected by adding calcium to the water, shoot for around 400ppm. Quote Link to comment Share on other sites More sharing options...
