CamaroZ Posted December 31, 2008 Report Share Posted December 31, 2008 I'm in need of the T that comes off the ozone that the temperature sensor attaches to for my 1997 Optima 850 Sentry. Would a dealer be able to supply me with this T or possibly a parts supplier online? Thanks, Tim Quote Link to comment Share on other sites More sharing options...
KIALDA Posted December 31, 2008 Report Share Posted December 31, 2008 The Temp sensor is located in the filter compartment on that spa, so I dont think that is the T that you are talking about. Are you looking at a t in the right side of the equipment bay? The ozone t is a mazzi and has a tube that leads to the ozone generator. There is also another T that would be a short way after the heater that has a wire coming out of it, that is a flow switch. Which one are you looking for? I would think any dealer would have all those 3 parts in stock. Quote Link to comment Share on other sites More sharing options...
CamaroZ Posted December 31, 2008 Author Report Share Posted December 31, 2008 The Temp sensor is located in the filter compartment on that spa, so I dont think that is the T that you are talking about. Are you looking at a t in the right side of the equipment bay? The ozone t is a mazzi and has a tube that leads to the ozone generator. There is also another T that would be a short way after the heater that has a wire coming out of it, that is a flow switch. Which one are you looking for? I would think any dealer would have all those 3 parts in stock. Sorry, I assumed it was a temp sensor. Yes the T in the right compartment! It comes off the top of the black cylinder next to the control box (I assumed that was the ozone). Then there is a sensor or flow switch on top and a fitting for a small tube on the bottom (I forgot about this tube in my original post) Quote Link to comment Share on other sites More sharing options...
KIALDA Posted December 31, 2008 Report Share Posted December 31, 2008 that is a flow switch, the part you need to locate is #6560-860. It is a very common part and you should have no trouble finding it. Quote Link to comment Share on other sites More sharing options...
