mlobitz Posted October 12, 2008 Report Share Posted October 12, 2008 First post here... Is there any difference between Spaguard 99% dichlor sanitizer ($10/lb from my local spa store) and the 99% dichlor for pools ($3.25/lb) at my local Target. Both come in similarly sized canisters. Spaguard is 5lbs and the pool concentrate(I forget the name) is 4 lbs. The spaguard is obviously for spas, but can the pool version from Target be used in a spa if it is the same concentration? Thanks! Quote Link to comment Share on other sites More sharing options...
chem geek Posted October 12, 2008 Report Share Posted October 12, 2008 First post here... Is there any difference between Spaguard 99% dichlor sanitizer ($10/lb from my local spa store) and the 99% dichlor for pools ($3.25/lb) at my local Target. Both come in similarly sized canisters. Spaguard is 5lbs and the pool concentrate(I forget the name) is 4 lbs. The spaguard is obviously for spas, but can the pool version from Target be used in a spa if it is the same concentration? Thanks! Yes, they are the same and either can be used. Quote Link to comment Share on other sites More sharing options...
