JJ1234 Posted July 8, 2008 Report Share Posted July 8, 2008 Now GFCI continually trips. Inside of pump compartment is relatively dry. Obviously water got under seal on topside button panel. Is panel shot or will GFCI stop tripping once the panel dries out? Thanks. Quote Link to comment Share on other sites More sharing options...
Roger Posted July 8, 2008 Report Share Posted July 8, 2008 Now GFCI continually trips. Inside of pump compartment is relatively dry. Obviously water got under seal on topside button panel. Is panel shot or will GFCI stop tripping once the panel dries out? Thanks. The GFCI will probably stop tripping when the panel drys out. But it will just get wet again so mayby a replacement or resealing is neccesary. Quote Link to comment Share on other sites More sharing options...
