USAFRET Posted July 6, 2008 Report Share Posted July 6, 2008 My first post, we purchased a Leisure Pools USA one piece fiberglass pool last fall (28' Roman). The dealer installed Hayward pumps/filters. In the last couple of weeks the Phantom Pool Clearer Quick Connect has started blowing pressuirized water from around the O-Ring. I have re-installed and set the pressure using the included gauge, and have inspected the male/female fittings along with the O-Ring and can not figure out why water would blow by the O-Ring. Before I contact my dealer I'd like to know what the problem is and if it's something I can easily fix. Cheers Tom USAF Retired PS: Here's a photo of our pool Pool Quote Link to comment Share on other sites More sharing options...
ps558 Posted July 6, 2008 Report Share Posted July 6, 2008 My first post, we purchased a Leisure Pools USA one piece fiberglass pool last fall (28' Roman). The dealer installed Hayward pumps/filters. In the last couple of weeks the Phantom Pool Clearer Quick Connect has started blowing pressuirized water from around the O-Ring. I have re-installed and set the pressure using the included gauge, and have inspected the male/female fittings along with the O-Ring and can not figure out why water would blow by the O-Ring. Before I contact my dealer I'd like to know what the problem is and if it's something I can easily fix. Cheers Tom USAF Retired PS: Here's a photo of our pool Pool Is the filter screen clean located in cleaner hose? Did the pressure release spring break? Quote Link to comment Share on other sites More sharing options...
USAFRET Posted July 7, 2008 Author Report Share Posted July 7, 2008 My first post, we purchased a Leisure Pools USA one piece fiberglass pool last fall (28' Roman). The dealer installed Hayward pumps/filters. In the last couple of weeks the Phantom Pool Clearer Quick Connect has started blowing pressuirized water from around the O-Ring. I have re-installed and set the pressure using the included gauge, and have inspected the male/female fittings along with the O-Ring and can not figure out why water would blow by the O-Ring. Before I contact my dealer I'd like to know what the problem is and if it's something I can easily fix. Cheers Tom USAF Retired PS: Here's a photo of our pool Pool Is the filter screen clean located in cleaner hose? Did the pressure release spring break? The line filter is clean. Not sure what you mean by "Did the pressure release spring break?" can you amplify??? I'm thinking I'll buy a few new O-Rings and see what happens. Quote Link to comment Share on other sites More sharing options...
