strenfam Posted July 4, 2008 Report Share Posted July 4, 2008 I have a question about the check valve at the top corner (air release?) of our solar panels. It seems to be gurgling when the pump is running (we can hear it from the ground). Does this valve need to be replaced or should it make sounds under normal operation? The pool and panels are only 3 years old. Misc info, we live in Florida, check valve has D2466 on it, the pressure indicator on the filter seems to be running a little high. Any info would be greatly appreciated. Joe Quote Link to comment Share on other sites More sharing options...
ps558 Posted July 4, 2008 Report Share Posted July 4, 2008 I have a question about the check valve at the top corner (air release?) of our solar panels. It seems to be gurgling when the pump is running (we can hear it from the ground). Does this valve need to be replaced or should it make sounds under normal operation? The pool and panels are only 3 years old. Misc info, we live in Florida, check valve has D2466 on it, the pressure indicator on the filter seems to be running a little high. Any info would be greatly appreciated. Joe I have had some of these air release valve leak from panels made from Smartpool. It is put there to release trapped air in the panels so it does not bubble at the pool return. If you don't mind a few bubbles at start up replace it wit a car or plug Quote Link to comment Share on other sites More sharing options...
strenfam Posted July 5, 2008 Author Report Share Posted July 5, 2008 I have a question about the check valve at the top corner (air release?) of our solar panels. It seems to be gurgling when the pump is running (we can hear it from the ground). Does this valve need to be replaced or should it make sounds under normal operation? The pool and panels are only 3 years old. Misc info, we live in Florida, check valve has D2466 on it, the pressure indicator on the filter seems to be running a little high. Any info would be greatly appreciated. Joe I have had some of these air release valve leak from panels made from Smartpool. It is put there to release trapped air in the panels so it does not bubble at the pool return. If you don't mind a few bubbles at start up replace it wit a car or plug Thanks for the info. Joe Quote Link to comment Share on other sites More sharing options...
timc_fla Posted April 22, 2011 Report Share Posted April 22, 2011 I have a question about the check valve at the top corner (air release?) of our solar panels. It seems to be gurgling when the pump is running (we can hear it from the ground). Does this valve need to be replaced or should it make sounds under normal operation? The pool and panels are only 3 years old. Misc info, we live in Florida, check valve has D2466 on it, the pressure indicator on the filter seems to be running a little high. Any info would be greatly appreciated. Joe D2466 is an ASTM designation for a PVC, schedule 40 pipe with solvent connected ends. They really should have used a threaded check valve for easier replacement. This application is most likely not an "air relief valve" but a "fluid check valve". What happens is the pool pump comes on and water is pushed up into and through your solar collectors. As this is happening the air is being pushed out of the solar collection system. When you turn the pump off, either manually or on a timer, the check valve allows air to enter the solar collectors and allows the water to "drain down". This is common and normal behavior. The sound you are hearing sounds like the valve is not seating correctly and is allowing some loss of water, as well as air. Perhaps a bug or debris has gotten into the valve either through the vent on the check valve or through the water from the pool or perhaps the spring and/or the neoprene seal inside the valve body has deteriorated. If you have a salt water system, salt crystals could have formed inside the valve preventing a tight seal. You could try squirting some water directly into the check valve from the vent in an attempt to dislodge any foreign material with the pump turned off and the system drained down and then checking the system with the pump turned on. If you still hear the gurgling sound, I would say to replace the check valve. Quote Link to comment Share on other sites More sharing options...
